Truck Starts Fine, Goes Down The Road, Power Drops, Sputters, Backfires...
...floored, keeps running.
The first time it happened I was running down the freeway, and hadda floor it so it would stay running, and got a huge, puffy cloud of grayish-white smoke in cab. Thing backfired, power way down--in the good ol' days, and in a C$%^&y, it woulda been jumped time from a sloppy timing chain.
Quits if I let it drop below 1,500 RPM. If I didn't know better, I'd say it's running out of gas. Runs fine, then intermittently does its run-outta-gas trick.
Fresh in-tank pump, 65 psig fuel pressure (specs).
Fresh fuel filter.
Truck: '91 F-150
Engine: 4.9L
Codes Read:
(Key On, Engine Off)
334--EGR Valve Closed, Voltage High
(Key On, Engine Running)
311--Thermactor or Air System Fault
538--Insufficient RPM change during KOER Dynamic Response Test
538--(Trucks ONLY): invalid cylinder balance test due to throttle movement during test
After sitting for 3 weeks, it fired right up and drove fine, after which I got those readings.
WTF?
Eddie
Fresh fuel filter.
Truck: '91 F-150
Engine: 4.9L
Codes Read:
WTF?
Eddie
omar1746
03-15-2016 08:43 PM
