1987 F-150 Horn Problem
1987 F-150, 174,000 miles, 4.9L, C-6, owned for 7 years
I am having trouble getting my horn to work. The stock steering wheel has been changed to an aftermarket Grant steering wheel with adapter. The adapter has two black wires that connect to the horn button on the steering wheel. One wire is positive and one wire is negative.
While I was troubleshooting with the ignition key in the off position I touched the + wire to the steering wheel adapter and the horn works. If I touch the + wire to the - wire coming from the adapter the horn does not work.
With the ignition key on I touched the + wire to the steering wheel adapter and the horn does not work. I touched the + wire to the - wire coming off the adapter and the horn does not work.
The voltage of the + wire with the key off is 12.4 volts grounded to the - wire or the steering wheel adapter.
The voltage of the + wire with the key turned on is 4.6 volts grounded to the - wire and 9.8 volts grounded through the adapter.
What do you think my problem is?
I figured out my problem today. Bad ground in the main harness. I created a new ground and now my horn works. It has been a long time since I had a horn! By the way I have a signature series wheel and followed the directions. The bad ground through me off because I assumed everything was perfect prior to installing the new steering wheel. Thanks for the help.
similar problem
I have a '91 F150 and the horn works when the key is off, but not when it is on. The cruise works sometimes, but the function buttons seem crossed up. When the key is off there's 12v or better at the horn and crusie controls, but when the key is on, it drops to about 6v. I suspect a bad ground, but don't know how to run another. Any tips?
ejs1968
16
03-22-2020 05:45 PM
daggerNC
18
11-07-2004 07:28 PM
