Changing fluids on a 1997 F-150 5.4L 4x4
At 60,000 to 70,000 the tranny, rear-end, front-end and radiator flush. When you get that many miles most people overlook the power steering and brake fluid change. You will spend about $250.00 to do all this. When you change the rear-end fluid, Dont forget to add friction modifier. (Get This From Dealer)
Ok how about the front and rear Diff, (they both take different fluids, front reg 80/90 weight and the rear synthetic gear oil +add 6 oz of non slip addative), Transfer, Transmission/filter/ flush, coolant/flush, power steering, and brake fluid. That about covers all that I would change at that mileage. It's alittle bit of work and fluids are expensive but worth it.
Lance
Lance
mike L
02-24-2006 09:04 PM
kyleC9959
04-28-2004 02:37 PM
