'53-'56 Battery Tray Mounting Question
How the heck does a stock 53-56 battery tray mount? I'm trying to make my own, and the pictures of a stock one don't make any sense to me. I can see that there are two bolts that hold it to the frame, but where does the other side bolt to? I can't imaging that it just hangs from the two bolts on the frame.
Any pictures or descriptions are appreciated. Thanks. - Brad
The running board bracket that holds the battery tray is different from the other five. It has extra holes and the lower section has a step in it to accommodate the battery tray on the lower level and the running board on the higher (outboard) level. Do you, by chance, have six brackets - all the same? If so, you're missing the special bracket for the battery tray.
6 brackets? Woahwoahwoahwaohwaohwaoh my head is spinning.
I'm hoping that since you have a F-250 that you have longer running boards and need 3 brackets per side. Both of my passenger side brackets are the same and have no provisions for a battery. I do however have an extra drivers side bracket that has the holes and such for the gas tank mounting.
Last night I used the drivers side bracket on the passenger side and fabbed up a battery box using angle iron and some threaded rod and it worked pretty good. I'll get some primer on it tonight and post some pictures tomorrow.
Thanks for your help - Brad
Looks like someone changed my battery tray in my 56. Mine mounts the same but is slightly longer and almost touches the inner fender plate (if you know what I mean). Maybe the picture Earl put up is for a 6V battery? or someone put a different year tray in mine. Needs to be replaced anyways, it's pretty rusted out. Great picture!
