1992 F-150 computer
Old 09-23-2005, 11:00 PM
arpco's Avatar
arpco
arpco is offline
1992 F-150 computer
Try as I might, I can't locate the computer. Can anybody help? Thanks, Phil
Old 09-24-2005, 01:45 AM
ford5.8's Avatar
ford5.8
ford5.8 is offline
Its in the firewall behind the parking break..
Old 09-24-2005, 01:59 AM
arpco's Avatar
arpco
arpco is offline
Thanks for the reply. I'll look in the morning. I can't believe I could miss something like that. Is it the same size as all of the EEC IV predicessors? Is there something covering it to make it impossible to locate. I've been blind sometimes in 30 yrs. of working on cars, but this takes the cake. Thanks again! Phil
Old 09-24-2005, 03:01 AM
cjjeeper85's Avatar
cjjeeper85
cjjeeper85 is offline
Its behind the drivers side kick panel.
If you want to take it out, the only way its coming out is through the firewall into the engine bay. Trust me IT WILL NOT COME OUT ON THE CAB SIDE OF THE FIREWALL. It took me an hour and a couple of busted nuckles to figure that out.
Good luck.
Old 09-24-2005, 07:22 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 09-24-2005, 07:32 AM
alabamabuddog's Avatar
alabamabuddog
alabamabuddog is offline
Mine is behind the inner fender well on the drivers side. Still behind the E brake but only access is from behind the tire.
Old 09-24-2005, 09:04 AM
RC Dan's Avatar
RC Dan
RC Dan is offline
Hmm... mine is up under the dash to the right of the gas pedal. It has a black and blue plastic case. So, if it isn't behind the kick panel, look for a plastic case. It should have two plugs in it.
Old 09-24-2005, 09:07 AM
pfogle's Avatar
pfogle
pfogle is offline
Dan, that sounds like the air bag module. The computer itself should be a metal case behind the E-brake pedal.
Old 09-24-2005, 10:10 AM
arpco's Avatar
arpco
arpco is offline
It's out! The two mistakes I made were 1)Don't expect comptuers to be inside passenger compartment 2) Don't trust Auto Zone's "component locator"!! It took me 5 minutes to remove it..thanks to you. Phil
Old 10-01-2012, 05:52 PM
TomFred's Avatar
TomFred
TomFred is offline
Question
Bumping...I've got a problem getting mine out. It is stuck in the hole and won't come out. Does anyone have any ideas? I've pulled everything, but I can't get the unit to come out.
Thanks!
Old 10-01-2012, 06:00 PM
danr1's Avatar
danr1
danr1 is offline
Thanks!
Rather then bump a 7 year old thread, start your own instead. Be sure and list the spec's of your truck too.
Old 10-01-2012, 06:11 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,173 Likes on 927 Posts
X2 for what dan51 said. BTW..if your truck is a 1991 or older the PCM comes out from the cab side.....
SuperSnake
North Carolina Chapter
06-20-2007 09:16 PM
hhandel
03-04-2005 09:32 AM
garyda
Computer Chips & Tuners
02-19-2002 10:59 PM
Quick Reply: 1992 F-150 computer
