351 C swap, 1967 F250 4x4
Hey guys
I'm thinkin of droppin a 2v Cleveland into my '67 Highboy to replace the worn slap out '74 360 that currently powers it, just wondering if anyone has tried this? i think i can use the FE frame stands, the motor will just sit alil higher, which isnt a big deal, and i even think i can make a set of 351M headers for a 77+ F250 work. Has anyone tried this? lemme know what yall think
btw it is a 4spd truck, and yes i do have the correct clutch/flywheel/bellhousing for the C
later
Dan
later
Dan
A 2v Cleveland does not have a high lift cam, and it's valves, while larger than a Windsor or an FE, are still not "big". I have a 351C 2v in my pickup (2 wheel drive only) and it has plenty of grunt. I have used it to pull out stumps, haul dirt, gravel, lumber, etc, and it never complains.
im aware i need a different clutch/bell/flywheel, i already have all that. i just want a motor that will make alil more power than the old tired '74 360 that is in it. the C is a fairly low mile motor and seems to run really well, i was gonna throw a dual plane intake and a small(around 268 advertised) split pattern cam in it, and see if i could make a set of 351M headers work, and call it a day.
thanks for the input, keep it comin!
later
Dan
later
Dan
i have been browsing summit racing....and pondering the 390 build as well, with Speed pro hypers going for only $21 each and summit having a cam/lifter/spring combo for $175, its tempting...but every time i start thinking 390...i start thinking 460, thats where my roots lie, you know? only way ill build a 390 is if i just dont feel like buying frame stands and expensive headers...
thanks for the input...
later
Dan
later
Dan
joelburn
09-01-2007 10:07 AM
rakent
02-01-2005 04:17 PM
Psycho_bob_1977
04-15-2004 03:24 AM
