gear swap ?'s
Old 08-31-2005, 10:59 AM
TINY G'S F150's Avatar
TINY G'S F150
TINY G'S F150 is offline
gear swap ?'s
I have a lifted 98 F150 2wd with 35's and my stock gears seem to be pretty sluggish after lift was installed. I am an old Mustang guy and in this case for a daily driver I would put in a set of 3:73's but I am not sure which gear would work best in a lifted truck that is going to be my daily driver . Any help on this would be much appreciatted. Does any one know the stock ratio? My gas mileage has suffered badly since lift was installed It wants to down shift going up hills and I feel a gear would really help out. Thanks
Old 08-31-2005, 12:25 PM
WVF150VIANC's Avatar
WVF150VIANC
WVF150VIANC is offline
There should be a stamped metal tag on one of your rear diff cover bolts showing the ratio.
You probably have either 3.08 or 3.55.
Rich
Old 08-31-2005, 12:31 PM
TINY G'S F150
OK WOW the Stang I had had a 2:73 so I geuss a 3:73 probably wouldnt be worh my time. What ratio are yall running in lifted daily drivers?
Old 08-31-2005, 01:54 PM
4dzilla's Avatar
4dzilla
4dzilla is offline
For 35" in tires I highly recommend using 4.56 gears.
Old 08-31-2005, 04:12 PM
TINY G'S F150
Is the 4:56 going to be good as a daily driver gear. I dont want to be wound out at 55mph but I definately need a better gear. I have 4:56 gears in a Ranger and it aint worth a dime on the highway but it isnt supposed to be its a racecar.
Old 08-31-2005, 05:41 PM
johnsonswamp's Avatar
johnsonswamp
johnsonswamp is offline
That depends on what ratio is in it now, auto or manual transmission? Motor size? What transmission do you have (i.e. AODE, E4OD, etc.)? Most transmission's have a different ratio, so if a 4.56 works good for one person, but they have a different transmission (or transfer case to, in a 4x4) than you, you most likely won't have the same results.
With that information we can calculate which gear ratio would be best for you.
Old 08-31-2005, 05:51 PM
TINY G'S F150
My truck is a 1998 2WD with a 4.6 automatic tranny. I will get under it tonight and see what gear is in it now. I appreciatte all the help. I will look for markings on the tranny to see what kind of tranny it is.
Sweet truck by the way
Old 09-01-2005, 03:47 AM
Bargod's Avatar
Bargod
Bargod is offline
You can get all that info off of your door sticker too.
Old 09-01-2005, 07:24 PM
cleevesj's Avatar
cleevesj
cleevesj is offline
I am running 4.56's in my truck with 36" Mickey's. Manual trans, 4.6 . It put my truck back to normal driving gear range or myabe a little shorter. My speedo is off about 8 MPH fast. Gas milage came back to normal also.
Old 09-02-2005, 08:55 AM
TINY G'S F150
It looks like this is going to be the right choice I havent had a chance to get the factory gear specs yet. I am not sure if the manual and the automatic on our year models are closely geared. Also my racing Ranger has a c4 so the overdrive will probably make up the difference.
Old 09-07-2005, 11:30 AM
TINY G'S F150
Well I climbed under my truck and the tag shows synthetic oil only on 1 tag the other has 8.8 but no gear ratio. I looked at the door sticker and it doesnt have gear ratio it only shows 18 under axle. My truck was built in 6/98 I dont know if this will help at all but thought Id try. Is there another way to get these #'s?
Old 09-07-2005, 11:58 AM
basecamp's Avatar
basecamp
basecamp is offline
If under axle it says 18, then you have 3.08 non limited slip. What does it say for transmision?
Old 09-07-2005, 12:00 PM
basecamp's Avatar
basecamp
basecamp is offline
If you look under the Articles/spec link at the top of this forum and look under ford door sticker decoder it will tell you all you ever want to know about your truck.
Old 09-07-2005, 12:48 PM
TINY G'S F150
tranny says U
Old 09-07-2005, 02:43 PM
basecamp's Avatar
basecamp
basecamp is offline
U is the 4R70w transmission.
Quick Reply: gear swap ?'s
