Torque spec for brake caliper bolts
Does anybody know what correct torque is for the caliper mounting bolts. My manual says 38 to 48 ft. lbs. I torqued to 38 and stretched bolts. Tried new wrench and bolts and it happened again. Called Ford and they said they don't have torque spec. for these bolts. Tried brake shop and they said same thing. My truck is a 97 2-wd.
Section 06-03: Brake, Front Disc 1997 Aerostar, Ranger Workshop Manual
REMOVAL AND INSTALLATION
Caliper, Lining and Front Disc Brake Caliper Anchor Plate, Ranger
NOTE: Refer to the Spindle, Wheel and Caliper Assembly illustration in this section.
Removal
Remove and discard sufficient brake fluid from the brake master cylinder reservoir (2K478) to allow for caliper piston displacement.
Raise and support the vehicle.
Remove the tire and wheel assembly.
Using a C-clamp:
Position the frame of the C-clamp on the inboard side of the disc brake caliper (2B120). Do not place the clamp frame over the front brake hose.
Position the C-clamp screw on the outboard brake shoe and lining.
Compress the C-clamp only enough to give removal clearance for the disc brake caliper.
Remove the front brake hose flow bolt.
Disconnect and plug the front brake hose (2078). Discard the copper washers.
CAUTION: Use care to retain as much of the original caliper slide pin grease as possible.
From the inboard side of the disc brake caliper, remove the two caliper slide pins.
Slide the disc brake caliper off the front disc brake hub and rotor (1102).
Slide the brake shoe and lining out of the front disc brake caliper anchor plate.
Remove the two caliper anchor plate bolts.
Remove the front disc brake caliper anchor plate from the front wheel hub and spindle (3K206).
Installation
Position the front disc brake caliper anchor plate on the front wheel hub and spindle.
Install the two caliper anchor plate bolts. Tighten the bolts to 98-132 Nm (73-97 lb-ft).
Position the brake shoe and lining in the front disc brake caliper anchor plate.
Slide the disc brake caliper over the brake shoe and lining.
Install the caliper slide pins. Tighten to 30-36 Nm (23-26 lb-ft).
Using new copper washers, install the flow bolt through the front brake hose fitting and into the disc brake caliper. Tighten the flow bolt to 30-40 Nm (22-29 lb-ft).
Install the tire and wheel assembly.
Lower the vehicle.
Refill the brake master cylinder reservoir with clean Ford High Performance DOT 3 Brake Fluid C6AZ-19542-AA or equivalent DOT 3 fluid meeting Ford specification ESA-M6C25-A.
Bleed the brake system. Refer to Section 06-06 .
Test the brakes before moving the vehicle.
Removal
Using a C-clamp:
Installation
Lower the vehicle.
pminne
07-29-2008 09:15 PM
