explorer O2 sensor location
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notified
Enjoy FTE....and
I have a 91 and a 94 so there may be differences. On the 91 there is one O2 sensor pre-catalytic converter where the pipes merge. On the 94 there are two O2 sensors both pre-catalytic convertor (one on each pipe from each manifold).
I think the 95 has three 2 pre (as described) and one post (may be mounted on top of the pipe at the post side of the catalytic convertor.
I'm only guessing on the third O2 sensor on the 95. If you want to know for sure get under an have a good look around. The pre-cat sensors are easy to spot. If you have a post-cat sensor you may have take a good look around for it.
Hope this helps!
Hope this helps!
rice975.0
01-25-2011 04:21 PM
islandsnow
08-08-2004 08:45 PM
explorerguy
1983 - 2012 Ranger & B-Series
01-05-2003 09:01 PM
