brake lights randomly coming on when parked
I have a 1999 F150 with the passive security system installed from the factory. from time to time the brake lights come on for a minute each time.
Also when the key is in the accessory position they come on.-Is my problem in the column or where?
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Sounds like the brake pedal return spring in the booster is leaving the pedal too low - right on the edge of engaging the brake light switch.
Try adding a helper spring from the pedal arm to a suitable mounting location under the dash to see if that helps.
It might also be an issue where the switch can be adjusted.
Steve
Steve
Chuck Fuller
02-15-2014 08:16 AM
mjfitting
10-26-2007 06:11 PM
