1997 F150 stalling
1997 F150 stalling
I've got a family friend who has a F150 with the 4.0liter engine. (?)
The problem is that he says it stalls, not constantly, more when it's cold, I believe, he turns the key off and then restarts and it runs. Sometimes it happens only once, other times it happens a few times.
The truck is equipped with a Diablo aftermarket chip. Bruce says it's worse with the chip turned off, than with the chip turned on. He's at a loss and maybe you guys could help us/ him out.
I did a search and did find something about the IAC valve so I copied and pasted the parts about cleaning and emailed that info to him.
Thanks
Rich
Thanks
Rich
Yeah I think he said he has the original chip. I will tell him about the battery idea. Part of the problem is he works overseas for weeks at a time and we don't see him to often. Perhaps could it be the truck sits to long? There by causing a build up of moisture or "crud" in the connections?
THanks for the reply
Rich
Rich
