Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-03-2005, 11:09 AM
tired-n-dusty tired-n-dusty is offline
Garage is empty, add now
tired-n-dusty is starting off with a positive reputation.
How About Vegetable Oil As Fuel
Recently I have been looking at some commercial systems that allow the use of vegetable oil in diesel engines. By the claims that the companies make it sounds pretty interesting. However, I realize they are selling a product and will usually only put forth info that makes them look good. What does anybody jnow about converting either a newer model PSD or a pre-PSD diesel to run on veggie oil?
Thanks for the input
Tired-n-dusty
  #2 (permalink)
Old 08-03-2005, 05:32 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.
This doesn't answer your question, but I remember seeing on a documentary someone taking/recycling used cooking oil from resturaunts, refining it, and then using it as motor fuel on a small scale. Obviously it must cost more per gallon to produce than regular dinosaur juice, or we'd see more of this...
  #3 (permalink)
Old 08-03-2005, 07:00 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
It can be done, I don't know on the PSD's, but at least on the IDI's with good success, but there are modifications necessary to prevent gunking up the internals. The oil needs to be heated to at least 180 degrees to get it closer to it's flashpoint. It also thickens when the weather is cooler, and has to be warmed up to flow effectively. Generally what is done is to have 2 tanks, one to start and warm up on, the other to run down the road on, then shut down again on regular type diesel.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #4 (permalink)
Old 08-11-2005, 10:00 AM
lmadore lmadore is offline
lmadore is starting off with a positive reputation.
I know a fleet mechanic that supervises the shop for the city. They recently switched to using alternatives to diesel. Biggest problem he noted was that the alternative (Bio and Vegetable oil) fuels tend to gum up the working parts if the vehicles are not run on a regular basis. If the vehicles sit for a day or two, they are really difficult to start and do not run very well.
Also, you will not get near the mileage out of alternative fuels. There simply is not as much energy in the alternative fuels.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
