1999 F150 4x4 I have purchased aluminum Wheels Part # XL34-1007 and center caps Part# XL34-1A096-AA these replaced the ford steel wheels but i can not get the center caps to stay on. does this require a different lug nut for the center caps? My local Ford dealer can't answer the question so any help would be greatly appreciated
Thanks! Center Cap problem solved. Now has anyone installed the Stainless Steel rocker panels if so does it cover up the rock guard at the bottom .
So what was the problem with the caps? I think the plastic rock guards need to come off. I had to take mine off when I put on my stainless fender trim. If I remember correctly they just have a few clips. If you look carefully the lower edge of the whole truck has kinda of a rubbery coating, it's pretty hard to chip.
I had to do a little bending and reshaping of the clips they fit pretty tight I mean I can't pull them off with my hand I hope they don't fall off that ford logo is pretty expensive at $50 a cap
The rubber coating at the bottom of the truck is what i'm needing to cover up with the stainless. my wife recently purchased a 05 Excursion and has decided it's to big and the Power Stroke makes a little more noise then expected so she's has ussumed my truck and ran over a planter on the edge of he driveway put few dings in the rock guard body man priced $1000 for repair
Glad you fixed the caps they should stay on. Sorry to here about the rock guard, you still need to cover up any bare metal before installing the stanless steel rocker panels. or rust will set in.
the stainless trim doesn't roll under the edges, which is what I think you want. Some of the kits are pretty bad and leave large gaps between the panels. There is a flexible plastic "diamond tread" trim that you can cut to fit, but I've never tried it so I don't know how it holds up.
