brakes fade when nearly stopped
I have a '99 F150 4.6l XLT
When applying the brakes everything is fine until I''ve nearly stopped, then suddenly I hear a grunting noise upfront and have no brakes. If I release the pedal and re-apply the brakes again more often than not the brakes will work. This problem has suddenly started occuring, last year I replaced the pads and rotors on all 4 wheels.
Anybody have any suggestions?
sounds like a bad master cylinder. does the petal go all the way to the floor? and I assume you have verified there are no leaks and there is brake fluid in the master cylinder. If this is the case the cups inside the master cylinder are allowing the brake fluid to bleed back through thto the master cylinder. The grunting noise is the brakes slowly loosening up.
Lance
Lance
rbrungard2012
30
01-06-2015 06:49 PM
Aufgeblassen
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
21
07-14-2014 05:39 PM
oldguard60
16
06-11-2014 04:39 PM
escapedtwice
Escape & Escape Hybrid
07-23-2013 09:53 PM
