should be next to the starter relay inside the engine compartment. try the inner pass. fender. if you follow your starter wires it should be next to it's relay. i'll double check my books for you later(there in my truck), if i'm wrong i'll get back to you
Found the fuel pump relay. It was located under the hood just to the right of radiator on the drivers side. It's mounted just above the horn on the engine side of front cowling with 2 small phillips head screws.
