1987 Ford E350 Motorhome Fuel Relay Location? PLEASE HELP! - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-07-2007, 07:56 PM
jayhawkcruiser
jayhawkcruiser is offline
jayhawkcruiser is starting off with a positive reputation.
Please help! I have a 1987 Gulf Stream Conquest Class C motorhome, mounted on a Ford E350 chassis. I thought I had it all figured out when it would start, but not stay running. I replaced the in-line fuel filter, the carb fuel filter and then decided to go ahead and pull the electric fuel pump. When that still did not work, it hit me that maybe the pump was not getting power. I took the old pump and hooked it directly to the battery and of course it works. Now I have spent all this cash and my parts guy says to try repalcing the $10 fuel pump relay. That would have been nice to know earlier! I got the part, and now I can not find the damn thing. Can someone please help? Inside? Outside? Firewall? I am trying to go out of town with my kids. While your at it...could it be anything else??? The pump is NOT getting power, but are there any other sensors, relays???? Thanks Craig
Old 07-07-2007, 08:25 PM
subford's Avatar
subford
subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Yes there are.
If I remember postings right they are on the firewall in the engine compartment.
If you have two fuel tanks you have two relays and an oil pressure switch with a bypass from the starter solenoid.
Let me know how many fuel tanks you have and I will post an electrical diagram of your fuel system.
Old 07-07-2007, 08:32 PM
jayhawkcruiser
1 BIG tank
It has a single big tank with an electric fuel pump that drops in from the top. The generator also pulls from the main tank, but I don't think that matters. Where on the firewall should I look? Passenger, Driver, High, Low?????? You said that it it is in the engine compartment, not inside the cab?
Old 07-07-2007, 08:50 PM
subford's Avatar
subford
Here is a diagram of electrical. The diagram is of a 1986 but I think the 87 was the same.
Sorry I can not help much on the location of the relay. If it was a truck it would be on the drivers fender but the guy said his E350 as on the firewall in the engine compartment and I could not get any more out of him.
When you find it let me know.
You may not have the in-line pump that is in the diagram.
Old 07-07-2007, 08:52 PM
jayhawkcruiser
Thanks
I will look asap and let you know. If anyone else knows a location, please let me know.
Old 07-08-2007, 06:52 PM
jayhawkcruiser
Found it!
Driver's side above the top headlight, under the lip on the radiator mount/nose of the body. Quick and easy. I removed the battery on that side to make sure I did not rip or break the fitting. The motor started right up
Thanks
Craig
Old 07-08-2007, 07:10 PM
subford's Avatar
subford
Glad you got it going and thanks for telling us where it was.
Where in Kansas are you located?
Have a good trip.
Old 07-27-2017, 03:46 PM
david clarence.
david clarence. is offline
david clarence. is starting off with a positive reputation.
1986 Ford E-350 Fuel Electric Pump Issues
One has a 1986 Ford E-350 Cutaway, running a 460 cu. in. 7.5 Liter 4-Barrel Carburetor, for a 27 Foot RV that has been plagued with fuel pump and sender malfunction issues for four years. Finally, found the problem - power to the Electric Fuel Pump Relay, Passes Through the Oil Pressure Sender Unit on the Rear of the Block, and that had an Intermittent Connection. Hope this Helps.
By: schroll, david clarence.
prochef
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-16-2018 06:07 PM
prochef
New Member Introductions
01-08-2018 11:50 AM
Reiki
38
04-19-2017 06:57 PM
Menoche
07-23-2016 04:15 PM
brendo613
06-17-2016 05:50 AM
Quick Reply: 1987 Ford E350 Motorhome Fuel Relay Location? PLEASE HELP!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
