Hi everyone,
I just purchased a 3 ton jack for my 99 Expy (4x4) and I was wondering what the best location was to raise the front. I also purchased a pair of 3 ton jack stands. I tried the side rail below the front doors and that raised it well, but I want to make sure before I do any work under the vehicle.
Thanks,
Keith
I thought that the side rail was part of the frame. Am I wrong? It definitely wasn't sheet metal that I was jacking up. I need to get underneath to change out my starter.
Keith
did anyone care to read the directions that came with the stock jack? Up front you are supposed to jack the A arms, there is a little lip where you are supposed to place the jack. In the back, you should jack on either side of the differential.
so then raise the truck by the side rails as you did before, and then lower it onto the jackstands that you place under the lip of the A arms... You have a jackstand under each a-arm, and the front of the vehicle is safely off the ground.
