99 Ford Ranger Supercab 4X4 driveshaft Thump/Clunk problem
Old 05-28-2013, 02:28 PM
nothingbutford46's Avatar
nothingbutford46
nothingbutford46 is offline
Question 99 Ford Ranger Supercab 4X4 driveshaft Thump/Clunk problem
I own a 99 Ford Ranger, Supercab 4X4 and am experiencing a thump/clunk noise in rear driveshaft when accelerating. The suggested action is to replace 3.5" steel driveshaft with 4.0" aluminum driveshaft. Does this correct the problem and if so, how?
Old 05-28-2013, 08:58 PM
reddog99's Avatar
reddog99
reddog99 is offline
I'm not sure of your exact driveshaft configuration, but that thump/clunk noise is a common symptom of the driveshaft splines in need of a cleaning/greasing, or of possible bad U-joints.
Old 05-28-2013, 10:43 PM
mfp4073's Avatar
mfp4073
mfp4073 is offline
agreed, dont throw it out yet. I bought mine 7 years ago now I think? Cleaned and greased the splines and have never had the problem return.
Old 05-29-2013, 11:53 AM
Rockledge's Avatar
Rockledge
Rockledge is offline
As mentioned, try lubing the slip yoke and see if that helps:
http://rockledge.home.comcast.net/~r..._Yoke_Lube.pdf
Old 06-12-2013, 08:46 PM
tjohnston28's Avatar
tjohnston28
tjohnston28 is offline
I also had this problem in my 98 Ranger. Replaced the u-joints and the problem went away.
Old 06-13-2013, 06:58 PM
Joe04F150's Avatar
Joe04F150
Joe04F150 is offline
Awesome thread guys, I think I'll be doing this over the weekend. I'm also getting a thumping noise coming from the front end at speeds between 15-50 I've changed both hubs and drive shaft u joints with no luck yet. But this will be another thing I can do and rule out.
Old 06-13-2013, 09:43 PM
mfp4073's Avatar
mfp4073
mfp4073 is offline
Just a note, when you go to do it you will have to cut off the clamps that hold the boots on. I used zip ties, two per position and its held for years now. Probably should replace them just because.....N/M....too lazy! If it works it works!
Old 06-14-2013, 05:57 AM
Joe04F150's Avatar
Joe04F150
Great idea, what type of grease did you use?
Old 06-14-2013, 10:04 PM
mfp4073's Avatar
mfp4073
mfp4073 is offline
to be honest, I know it calls for special grease. But I used white lithium. Figured if it didnt work I could get the good stuff.
f_lococo
06-02-2010 06:46 AM
sbappleg8
10-06-2008 07:50 AM
dell
07-27-2005 04:23 PM
Thompy
09-09-2004 08:38 PM
Quick Reply: 99 Ford Ranger Supercab 4X4 driveshaft Thump/Clunk problem
