It means your Heated O2 sensor on the passenger side, before the catalytic converter, is acting up or is reading a lean condition in the exhaust system on that side of the engine.
A lean condition can be the result of a leaking intake manifold gasket on that side of the engine, or it could just be a bad O2 sensor. Without further diagnostics it's just a guessing game as to which solution would solve the problem.
