Anyone install 6.5 speakers in a F-250?
Yes, I run Focal 2 way components in the front door and had to fabricate a plexiglass plate in order for the tweeter to fit. If you are just running a single woofer then you can bolt it right on (might need to drill another hole in your door depending on the speakers hole alignment) I would highly recommend that you use some sound deadning material (dynomat) to cover up the gap. Good luck
I have the Focal K2P. You will love the Utopias . I put the tweeter about 1 inch above the woofer. I wanted a stealth install for myself but a tweeter will fit in that location you are thinking about. If you install it there then you really don't need a panel. Just cover your speaker hole with a rectangle piece of Extreme Dynomat (it works great), draw a 6.5 circle (Focals are a true 6.5, unlike some other brands) and mount your speaker. Mount your tweeter and connect it to the crossover (that is double sided taped to the inside of your door panel metal and you are set. Good luck, what else are you planning to install?
Thanks for the Info. I'm going all out. I have always been an Alpine man. Alpine IVA-D300 with the Navigation, TUA-T020XM, for XM radio. MRV-F545, MRD-M605 SWR-1242D. And of course the Focal Utopias. I,m also going to install the Clifford RSX 3.5 remote start alarm for some sort of peace of mind.
You will definetly be happy with your set-up. I just got finished speaking with Focal-America's tech guy and he recommended that the tweeters be mounted in the a-piller facing each other on a slight pivit. If you need some assistance with your set-up his name is Dwayne and can be reached at (805)484-2485. You will love the clifford alarm. I have always had clifford in the past but purchased a Viper 791xv 2 way, remote start fully loaded with all the bells and whistles alarm. I am pushing my focals with a jl 300/4 amp, have an Image Dynamics IDMax 12 (installing this weekend in a custom King Ranch Center console) with a JL 1000/1 amp. The Amps are installed in a Plexiglass and almost matching brown leather Custom Amp box. I have an alpine cda-9835a great set-up. I also have Tthe UA-T020XM and the antenna mounted under the wiper cowl (Stealth). I guess I will be mounting my tweeters in the A-pillar black cover. Good Luck and post some pictures whenever you have everything installed
I have a total Alpine system as well
XM/Sirius and cd changer and other acc
Not to derail the OP but I'm about to fit 6.5 JL Audio C3's into my '03 E250.
Looking at the door mounting surface and how the interior trim panel possibly will interfere with the sound I'm curious if I'd be better off mounting them to the trim panel somehow?
I will be using them co-axially, not separate tweeters.
Big-Sarge
6.7L Power Stroke Diesel
47
01-17-2024 10:32 PM
BigBore44
28
08-22-2015 09:20 PM
97HD4X4
10-30-2003 11:50 PM
