Headlight Removal on 92 F250
Old 05-30-2005, 11:32 AM
PureGrunt's Avatar
PureGrunt
PureGrunt is offline
Hi Everyone,
I have a 92 F250 and I need to replace a headlight (not just the globe, but the whole unit), but I can't figure out how to get it out of the truck. I can see the screw that hold the headlight in, but I can't get the pretty chromed plastic light surround off, to get to the screws to remove the headlight
Can anyone give me some clues as to what I'm doing wrong?
Many thanks
Old 05-30-2005, 11:50 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
FghtinIrshNvrDie is offline
I am having the exact same problem on my 94. same headlight unit if I'm correct
Ryan
Old 05-30-2005, 02:16 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
Passanger side...
Remove battery.
remove the two 10mm nuts behind turn signal lights
remove the two screws on top holding the trim on
remove electrical connections
remove turn/corner signal assembly
access to headlight lense - remove (I did so by just unscrewing the adjusters)
Drivers side is the same as the passanger side except you've got to move the coolant/washer tank. Theres 1 11mm bolt holding it on, two hoses connected at the bottom, 1 electrical connector. You can unbolt it, and sit it ontop of the air box. I took a tiedown strap I had nearby and wrapped it around the tank and the hood spring to hold it ontop of the airbox. That way I didn't have to remove any hoses and deal with fluid leaking everywhere and it would hold the tank out of my way.
Getting the lights back in is the same as the removal, the 10mm nuts on the back of the turn signals are a pain to put back in. I used a 10mm deep socket, put the nut in the socket, and put a dab of grease on it. That holds the nut in the socket, and you can just screw it on. Don't go too tight, just snug it past finger tight.
Old 05-30-2005, 09:58 PM
Sn0wMan's Avatar
Sn0wMan
Sn0wMan is offline
Mustang did a great job of explaining... i was a little late gettin to the threads and he beat me to it lol. Ive got pics in my gallery of some that i bought from ebay. Make sure you remove the battery and coolant overflow/windshield resevoirs, save you a TON of frustration, good luck.
Bikedude987
03-20-2012 09:41 PM
farmalldude
1999 to 2016 Super Duty
08-28-2008 07:51 PM
1957F100
08-23-2007 12:26 AM
jhopkinson
07-22-2007 12:18 AM
HUNTER10
03-10-2007 08:50 PM
Quick Reply: Headlight Removal on 92 F250
