Off road light bar
Off road light bar
I had bought some nice off-roadlights for my truck and I dont like the whole idea of them sitting on my bumber I dont think it looks that good but Id rather put them on top of my roof on a light bar I saw a bronco driving around my town with one it looked real nice and all but I noticed that it is starting to bend a little in the middle I was woundering if anyone out there has a site for where I can buy a light bar for cheap or if theres a way I can build one with some old bed frams I have in my cloest theres nothing wrong with them tI just bout a new fram for the hell of it but I had bought 4 SBS blue off roading light and would like any suggestions but please respond thank you
KC sells probably the best. if you skimp on quality youll pay for it later. something else to think about is putting lights on the top will reduce what you can go under or thru , also at night when they are turned on produce a major glare off the hood making it hard to see. do a search online an see what you can find. also check out jbg
I once saw a bronco with a storage rack mounted on the shell. It had a shovel mounted on one side and an off-road jack mounted on the other. It had lights pointed forward, rearward and on each side. It looked really cool. Only problem I saw with it, is that it would not fit into my garage or inside some parking decks. It probably took a high output alternator to run all the lights.
3g is just an all around better alt for our rigs. problem is they werent offered till later years. go to www.fordfuelinjection.com you can buy the harness to make the swap plug and play and there is a list of rigs that you can find the hi amp alts at your local wrecking yards for cheap.
