View Poll Results: Seafoam.....your take on it......poll
I used Seafoam a few times, and it does the job, and truck ran better with no ill effects.
73.68%
I used Seafoam before, but it messed something up on my Bronco.
0%
Voters: 38. You may not vote on this poll
1. I have used Seafoam a few times and it had always worked as advertised, without any ill effects on the Bronco, and it defiantly ran better than before.
2. I used Seafoam once it worked ok with no problems, but I felt/noticed no difference in how the truck runs.
3. I used Seafoam once and it did nothing but mess up my truck, or made it run worse.
Back in the 70’s (1970’s) we used to pour something similar down the carburetor while the engine was running and it would smoke up the whole neighborhood. I think it was supposed to clean the valves. I don’t remember it making much difference in the way the vehicle ran. It was probably some kind of thin oil that was sold as a cure all.
I don't have noisy lifters at 169K on my 5.8 nor oil consumption but possibly low oil pressure (still use factory guage that reads low). I swiched from 10w30 to 20w50 and get very little pressure increase. What is the best way to flush crankcase with Seafoam? Also did it start oil leaks or increase them?
I use the fluid and aeresol version on my outboard boat motor. I run the fluid through my gas and the aeresol version gets sprayed into the cylinders via the spark plug holes. It works wonders for my outboard. I've never tried using it on a vehicle but can't see why it wouldn't work there as well.
Around my neck of the woods Napa autoparts stores carry both versions.
Seafoam quickly cleared up a fuel problem in my 99 snowmobile (2 cycle 500 CC motor), ran great afterwards, barely started before. I like Marvel Mystery Oil, been using it for years in my gas on long trips, and it does increase gas mileage. Not sure about the effects on catyletic convertors.
