Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-05-2005, 06:03 AM
afinepoint afinepoint is offline
afinepoint is starting off with a positive reputation.
Aluminum wheels dull. How to polish?
What are the stock aluminum wheels on a 01 Lariat F350? Polished or not. Mine look heavily oxidized. They were badly scratched and nicked by the previous owner.
I tried some chemical cleaning clothes in a small area of the wheel but it turned that spot black. The resultant smear does not want to come off.
Can they be buffed with a power tool?
Reg
__________________
2001 F-350 7.3L crew Lariat 4X4 dually 8' bed, 6637 filter, straight pipe, chipped by Dp tuner, on board air and train horns (see em under Articles).
  #2 (permalink)
Old 05-05-2005, 07:17 AM
bulldog3531 bulldog3531 is offline
bulldog3531 is starting off with a positive reputation.
get some mothers wheel polish. it works great on my wheel made them look almost new.
  #3 (permalink)
Old 05-05-2005, 11:25 AM
stephenw stephenw is offline
stephenw is starting off with a positive reputation.
I just tried Meguiar's NXT Metal Polish - great stuff!
I've been using Mother's and Blue Magic for a long while and was always satisfied with them, but recently got some Meguiar's NXT to try. They all take some elbow grease, but the Meguiar's beats the others for a crisp shine, hands down. Steve
  #4 (permalink)
Old 05-05-2005, 05:07 PM
CobraXP's Avatar
CobraXP CobraXP is offline
CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold
Mequiar's for me, but Mother's always did a good job also...
__________________
David
FTE Super Moderator
Join us in the Utah Chapter!!!
When you can't buy what you want, build what you want.
  #5 (permalink)
Old 05-05-2005, 06:15 PM
Thanks.
Reg
__________________
  #6 (permalink)
Old 05-06-2005, 10:38 AM
WiscoAndy's Avatar
WiscoAndy WiscoAndy is offline
WiscoAndy is starting off with a positive reputation.
anyone try that ball thingie made of foam rubber that attaches to a drill so you can spin the polish on?
My wheels may need a lot of elbow grease if by hand.
thx-Andy
  #7 (permalink)
Old 05-06-2005, 04:20 PM
I agree. Some sort of buffer application would be welcome. I used some Never Dull metal polishing wadding. It does clean the wheel but because of the level of oxidation I used many square inches and 10 minutes to shine a spot about half the size of my palm. At that rate I will need a entire can to do one wheel and probably >hour/corner.
The front wheels because they extend outwards are so nicked that I am thinking of just replacing them.
It's like the previous owner used the wheels for target practice with sharp objects.
Reg
__________________
  #8 (permalink)
Old 05-08-2005, 02:28 AM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE. furball69 has a very good reputation on FTE. furball69 has a very good reputation on FTE.
Rent yourself one of these: http://www.mytoolstore.com/milwauke/5223.html
And buy yourself some of these: Ebay.com #3763802371
And some of this: The green rouge
http://www.caswellplating.com/buffs/compound3.html
For about a hundred bucks or less and a couple hours work your wheels will look like new.
  #9 (permalink)
Old 05-11-2005, 02:01 AM
RomerB2's Avatar
RomerB2 RomerB2 is offline
RomerB2 is gaining momentum as a positive member of FTE.
Every month or so I get in the mood to clean my truck and make it shiny and stuff and I have a 90 Bronco II that gets a lot of brake dust, oxidation and other things on it. I used some Mothers Aluminum and Mag polish the first time I did this. Took me about 30-45 minutes a wheel but I took them off to get inside the holes and everything. They looked almost like new just had a few knicks in them. Now that the oxidation is repaired I just use the spray on wash off stuff and they look great.
  #10 (permalink)
Old 05-16-2005, 09:11 AM
7fords 7fords is offline
7fords is starting off with a positive reputation.
start with 00 steel wool and work your way to 0000 steel wool then use your buffing wheel with jewelers rouge they will shine like chrome
  #11 (permalink)
Old 05-23-2005, 07:40 AM
1stfordtrck's Avatar
1stfordtrck 1stfordtrck is offline
1stfordtrck is starting off with a positive reputation.
i use sand paper depending on how deep the scratches/curb rash is and work ur way 2 a very fine grit then use an aluminum polish lots of work but makes them as smooth as glass look on my cardomain me and my dad did the tpi on our camaro that way
__________________
1965 ford f-250- (hopefully soon)
1985 camaro z28- http://www.cardomain.com/id/jeffsz
ANTI RICE-my coke bottle has more liters than ur 4 cylinder that doesnt make enough torque 2 tighten my lug nuts
  #12 (permalink)
Old 06-09-2005, 09:19 PM
I got around to working on one of the wheels. Using a brass wire brush, a three step polishing compound and finishing off with Never Dull-a metal polish I managed to get a bright shine however . . . The wheel(s) is (are) so badly scratched and nicked that the shine now brings out those flaws. They stand out like scratches on a mirror. The dull wheel on the other side actually looks better.
I could buff out the flaws but like someone else mentioned doing this by hand will result in a rippled surface. I have resigned that new wheels are the answer.
Thanks for the help.
Reg
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
