I have a 1999 Mercury Mountaineer that just started leaking washer fluid out of the rear wiper nozzle. It only does it when it is the car is running. I am thinking it may be the pump or maybe switch. Has anyone had this problem?
I've not had the problem on mine but I would bet it is a problem with the nozzle or the line feeding it. Check for cracks. Not sure the pump would be the problem but you never know.
I was considering that also, maybe thinking that if there was a hole or something in the end of the line near the nozzle that it may be acting as a siphon.
Everything looks fine. Can someone look at thier rear washer and see if the nozzle squirts out three holes, two up and one down? I don't remember it shooting over the car before as it does now.
Thank you,
bdp
Something is causing the pump to run. Check to see if a relay controls the pump and replace it or change it with another relay then replace it. You could also have a short in the wiring.
