Symptoms of Bad U-joints?
Hi Folks,
I'm sure this has been covered many times, but my searches for (+u-joints +replacing) gives me hundreds of unrelated threads. Hmm...
Anyway, I recently lifted my 2002 F250 PS with a 3.5" spring-hanger kit, and now I'm starting to regret the decision. I love the look of the 315 R/75 tires, and the stiffer ride of the dual Bilsteins in front, but nagging ride issues persist.
After solving my "drive-away shudder" problem by shimming the carrier bearing, the truck was smooth at all speeds, but only for a short time. Then, I began noticing vibrations at speeds above 45 mph. I suspect it's drive-line related because it only happens under power, it still coasts smoothly. I had the tires rebalanced, anyway, just to rule out the easy fix.
Now, I'm thinking u-joints, but before I jack the truck up and start shaking parts, I wanted to see if you guys felt I'm on the right track. I'm a "shade-tree mechanic" at best, but I figure I can handle u-joints.
Any tips, or alternative ideas will be most appreciated.
Matt
Matt
My thoughts and a question
As for the U-joints, the best way is to get under your truck and wiggle each d-shaft at the joints and check for any movement at all, if they look like they are moving at all when you wiggle, then you have some U-joint wear as there shouldn't be any play.
As for the 'drive-awa shudder', you got my attention. When I pull away at a moderate pace, I don't get the sgudder, BUT, when I HONK on it, I get a shudder for about 2 seconds, I never thought to check the carrier bearing. This leads to my question, do you have a lift kit? I have an 8" lift with the drive-line geometry in good line, my next question, does the 'rubber' lining of the carrier bearing housing wear and create too much play???
Cheers!
Cheers!
Thanks for the quick reply Kalsc,
I just crawled out from under the truck. There's definitely play in the rear joint. Front and middle are tight. Looks like I have an afternoon project. ;-)
Yes, I have 3.5" Fabtech spring-hanger lift on the front, 4" blocks in back. I noticed the drive-away shudder the moment it was installed. Same as you described...only noticeable under heavy acceleration. (3) 1/4" flat steel shims eliminated the problem on my truck, but the amount of shimming varies depending on lift height and axle-to-axle length.
Matt
Matt
gb5
12-19-2016 01:22 PM
Scotty's 52 F3
10-25-2015 01:20 AM
Kalashtar
01-18-2006 12:11 PM
