Still dealing with a fresh gas smell
Old 03-20-2005, 09:58 AM
Mikeleew's Avatar
Mikeleew
Mikeleew is offline
Will someone please describe for me the proper routing of the vent tube for my 65 Econoline? It is currently coming out of the top of the tank, through the frame, up into the back quarter where is then loops back down and is forced into a hole in the frame. I still have no leaks.
Thanks,
Michael.
Old 03-21-2005, 08:21 AM
66gpw's Avatar
66gpw
66gpw is offline
It sounds like your venting tube is running in the right area.
Is the problem that you are getting a gas smell. Am I right. You then may have holes corroded in the pipes. I had to fix mine and what I used was just some rubber hose connected to the pipes at both ends. There should not be any gas running through this pipe as it is to vent and keep the pressure equal in the tank.
Is the pipes plugged, thus not allowing proper venting. See if you can blow air back into the tank.
Make sure you have no gas line leaks along the route to the engine. You checked the lines at the fuel pumps and carb. That could cause the smell to enter the cargo area of your van.
First make sure your lines are not plugged or corroded causing the smell to come inside.
Old 03-21-2005, 03:37 PM
Mikeleew's Avatar
Mikeleew
Mikeleew is offline
Smile What Pipe?
What pipe are you talking about? Is there a pipe in the frame that the vent tube is plugging into? I believe my new vent tube goes high enough that no liquid is making it to the end. I have no visable gas on the ground that I can see.
I will be replacing the pump, fuel lines (hard and soft), and putting on an edlebrock intake with 4 barrel carb in the next week or so. I will also be installing a new HEI distributer and gas shocks. Any advice before I start all of this?
Thanks,
Michael.
682bear
11-03-2016 06:25 PM
Shawnboylk
05-09-2016 12:28 PM
red450ih
03-08-2015 04:33 PM
Redmanbob
01-18-2009 09:20 AM
sglaine
Ford vs The Competition
72
04-23-2008 06:24 PM
Quick Reply: Still dealing with a fresh gas smell
