Wiring plug, 2-stage vs 1-stage trailer brakes!?!
I was installing the new 6-round plug on my 85 F-250, it already has a brake controller. I was checking to see if there was power from the brake controller to the plug(PO hacked them off at the old plug). I have a big red wire and a big blue wire. I knew the blue went to the brakes, and thought the red wire was for aux. power, but it appears to be a 2-stage brake system. If I push the pedal halfway, I get power from the blue wire, if I push the pedal all the way, I get power from both wires. Do I need to connect both wires, I have a 20' flatbed with 4 wheel brakes, but it only has one wire for the brakes. Would I be okay just hooking up the blue wire, and capping off the red one, or should I connect both wires to the one trailer brake wire? Did I mention I hate electricity?
try this site below. It show the schematic for a 7 pin - 6-pin and other stuff.
http://firefyter_emt.tripod.com/elec.htm
There is a wheel on the bottom to make some kind of adjustment, and then the slide control **** on the front. There is also a pad on the inner fender with a U shaped spring, that has a clamp connecting the sides, with arrows indicating which way to move the clamp for more or less trailer brake. I just checked the Tekonsha site, and with out a model type, it's like a needle in a haystack.
I have another controller to stick in there, but I didn't want to take the brake line apart and have to bleed the sytem yet. I figured I would just use this one for a bit. If I do swap in the other controller though, would I just need the blue wire? I shouldn't have to worry about the red one? I believe the other one is a 2030.
I just found a wiring diagram for the 2030 on the Tekonsha site, white is ground, blue is brakes, black is power, and red is brakelights. I will try the old one with just the blue wire for now, and eventually get the 2030 installed this spring. I hate the thought of bleeding brakes just because I uncapped 1 line for a few seconds. I will probably throw on a new Master cylinder while the lines are apart, so it's not a total waste.
I wont be hauling anything too heavy for awhile, so if it gives me any trouble, I will just disconnect the wire until I get the other one swapped in. The last truck I pulled this trailer with didn't have a brake controller, and I never had any problems with it. I just took extra caution in judging braking distance and following other vehicles. Since I have a brake controller now, I figured I may as well use it.
metriccar
04-25-2012 11:05 PM
Aggie05
1983 - 2012 Ranger & B-Series
08-17-2009 03:23 PM
trike1946
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-16-2005 08:14 AM
ccrider966
09-19-2004 02:50 AM
