ABS Light is on
ABS Light is on
I just repalced the Hubs,Rotors and Calibers on my 95 Bronco. As I was comming up to a stop sign I applied the brakes in a calm mannor.
The brake peddle locked up. It was right at the top and like stepping on a rock. I heard what sounded like a motor trying to work and had a vibration in the brake peddle. I almost didn't stop. I let off of the brakes and reapplied them. They work fine but the ABS light came on.
When I start the truck up the ABS light will come on then go off like it did before. But comes on after a short time and the same thing happens like at the stop sign. After the light comes on the brakes work fine just no ABS action.
Any Ideas on what could be the problem. I would be greatful for any help
Thanks
BB 5.8
Thanks
BB 5.8
There is a "Speed ring" on the backside of the caliper assembly and a sensor that monitors the ring. If the sensor got knocked out of place or damaged it can cause problems like you are getting. Pull the wheel and ckeck it out to make sure it is lined up, not hitting on the ring, connected to the wiring harness...etc.
It could be that, that would be nice if it was. On mine I had to replace the ABS valve that is located on the front driver's side frame rail. It was making the front brakes drag for one thing, and the ABS light always came on if I let the truck idle for 10-15 minutes in hot weather but I am not sure what that meant. The red light would come on as well. By the time I found the problem the ABS light and the red brake light were on almost all the time, and I was warping rotors from the drag of the calipers. All fixed now but that valve is not cheap.
But you probably do not have that problem as it only started after your brake job so the ring may have gotten lost or damaged during the intallation.
Originally Posted by BillyBob69
It would be kind of tough to loose the ring...its not much smaller then the diameter of the rotor. Let us know what you find out.
Maybe I don't have the ring, since I have a 1990 and it only has ABS on the rear wheels?
So you only have the rear ABS or the 4 wheel ABS? ....check this site for info
http://www.autozone.com/servlet/UiBr...3d800aa2ef.jsp
4 wheel wasn't available for the Big Broncos til 93. My bad...I was thinking newer setup.
anthonyh75
1999 to 2016 Super Duty
11-15-2016 08:54 AM
radmacks
04-10-2015 10:18 PM
351whitewindsor
08-09-2009 11:21 PM
