How to replace your Super Duty Ball Joints
#707
That way won't set them to the right depth.
Removal
Watch this part to see how to set the seal
You are going to need the tool or make one. I think someone
has some plans on making one to do this.
Sean
6.0L Tech Folder
Removal
Sean
6.0L Tech Folder
#712
Here is one site (there are others) that explains how to make the seal tool.
Ford Super Duty Knuckle Seal Tool - AKA OTC 6695 | Superdutypsd.com
found out the hard way it is from 05+ the axel is larger at the stub axel end.
I had the tool from the local odd-ball tool shop that has the Lisle tools and
that one went to 04. They don't have one for the larger axle. Looking at the
Ford tool it is not a flat face. So you almost need that tool to get it in correctly.
Sean
6.0L Tech Folder
#714
You won't believe how I got it in place.
Pneumatic 3X rivet gun set on very low with a Rubber-Guard Flush Set
to slowly tap into place.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
#715
#716
Depends on mileage and wear etc. They last quite a while...Replace with spicer life joints. I cut them out because any pounding and the ears bend. They are big joints and come out hard. I would say if you are closing in on 100k you might want to replace them. esp if you are in a salt area..Oh and welcome to the site...
Dick
Dick
#717
Dick
Dick
#718
I just completed this job on a 1999 F250 SD, V10, 4x4, Auto. I think I have read most of this thread from the beginning. One thing I encountered that wasn't touched on to much to my knowledge, or I just missed it. I had one heck of a time removing the factory auto/lock vac hubs. Worst part of the whole job for me. I recently purchased this truck, and don't know its life history. Has 129,000 mi. on it. Not bad for a 16 year old truck. But the rust/corrosion on the suspension parts is another story. Mine is a early model 99 to boot.
Both sides were the same. Were in auto position, but both were actually locked. One outer retaining ring came off pretty easy, the other not. I soaked repeatedly with PB Blaster throughout this process. Started off with rubber mallet. That got me nowhere. Proceeded with ball peen hammer, no luck. Then heavy hammer. Ended up just breaking them and using chisel. I beat, soaked, beat and soaked some more. After about two days I got some movement. Same both sides. I finally got them off. They were rusted/corroded fast to the inside of the wheel bearing hub assy.
The vacuum hoses were long gone from this vehicle it appears. I cleaned them up, best I could, lightly greased them, and decided to go the route of aftermarket manual hubs. So far they work great! I think I will remove them every so often in the future, to check on them and lube them. Replaced all the steering tie rods parts etc, shocks while I was under there too. New tires, and alignment to boot. I used all Moog heavy duty parts, and Mile Marker manual hubs. The truck drives great now! Lots of cussing, time and PB Blaster! and $$$ later.
Gregg,
Gregg,
#719
#720
Dick
I never thought to measure the rotors for dia. or thickness. Its funny, the rotors and brake pads were in very good shape. Looks like the pads were changed not long ago.
I think the build date on the door on mine is like 5/98. So it must be a VERY early one.
Most of the dates I have seen between early & late, is like 3/22/99.
Gregg,
Gregg,
