Bent pushrods ?
First thing that comes to my mind is over reving it. You also could have had a lifter stick in its bore, thus hitting the piston, and when the piston hit it, it would have bent the rod. also a sticky value guide, possible wet stacked, that could have caused excess load on the push rod and bent it. hopefully barebackjack will chime in, he just fixed his motor. had the same problem.
Diesel Rod
Diesel Rod
Originally Posted by jakemb
Thanks for the reply.What is wet stack?
ford truck oldboy460
01-28-2009 09:28 AM
78ford_shortbox
03-01-2006 01:34 PM
fordman428
08-30-2004 09:02 AM
