1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
V10 Coil Pack Failure
Old 02-13-2005, 05:41 PM
Tazman's Avatar
Tazman
Tazman is offline
Has anyone besides me had Coil Packs die? I've got a 01 F250 CC long bed 4x4 with 36,300 mi. Bought it new, just don't drive it that much (since the two of us have four other vehicles). At 35,500 mi , under warranty, it started running rough at low RPM (1500-2000) in OD. Took it to dealer and #8 Coil had died.
This last week it has started again. Since it's out of warranty they want $100 to plug in their computer and less than 60 seconds later tell me which coil died. Maybe I'm tight or cheap ( I like to think I'm frugal), but I think $100 a minute is a bit salty. Does anyone know of a quick way to tell which one has quit? Ford want's $100 a piece for the Coil. Advance Auto has them for $54.
Thanks,
Tazman
Old 02-13-2005, 05:50 PM
wolfbike1500's Avatar
wolfbike1500
wolfbike1500 is offline
Do what I did. Buy 2 of the 50 dollar items and replace the front 2 coils. Take it for a drive. If it runs fine problem solved. If it still runs lousy, take the 2 you just replaced and put those in place of the ones right behind the front 2. Repeat as required until the problem is solved. I did 2 coils at a time because I'm too lazy to climb under the hood potentially 10 times. You may also want to consider replacing the boots while you are under there. Cheap enough to do 6 bucks each.99 F-350 CC LB V10 Lariat 4x4 SRW
Old 02-13-2005, 06:56 PM
Tazman's Avatar
Tazman
Tazman is offline
Good idea Wolf. I think while I'm at I'll check to see if I get a reading on my VOM on the front two. It would be nice if you could pull the lead off and see an open circuit going toward the plug. I'll let everyone know if this is a good test for bad coils. I'll have to wait for a little better weather, with a tall fiberglass shell on my truck, it won't fit inside.
Thanks,
Taz
Old 02-13-2005, 07:01 PM
V10MARS's Avatar
V10MARS
V10MARS is offline
If it's missing at idle....You can unplug the power lead to each coil untill you find the one that is dead.
Old 02-18-2016, 02:51 PM
LazyFordBakyardMec's Avatar
LazyFordBakyardMec
LazyFordBakyardMec is offline
I had the same problem but I was able to diagnose which cylinder was misfiring more easily. I have an actron cp9575 auto scanner that I picked up for less then 50 bucks. The scanner indicated an error code which told me that cylinder number four was misfiring. I replaced the COP which fixed the problem. I have used the scanner to correct other problems too which saved me time and money.
Old 02-18-2016, 05:10 PM
Wolfboro's Avatar
Wolfboro
Wolfboro is offline
A vacuum leak can also cause rough idle . Check your PCV hoses and its plastic 90 degree elbow for any cracks.
Already good suggestions were made (like swapping a new coil ).
Unless your truck is an OBDII compliant (means built for CA or some other northeast green states) I doubt that you would get any misfire reading with any scanner (Check the sticker under hood see if it is OBDII or OBDI ).
In V-10 forum , most reports show that these COP coils easily last 100K+ miles .
I suggest you do some troubleshooting . Good luck.
Old 02-18-2016, 06:27 PM
LazyFordBakyardMec
P0304 Code - Cylinder #4 Misfire
Old 02-19-2016, 12:56 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
10 year old thread, just got bumped.
EntoMan
1997-2006 Expedition & Navigator
02-13-2018 10:53 AM
The Hooligan
11-29-2016 01:33 PM
tazman1031
16
10-03-2016 09:01 AM
V8SHO
30
03-16-2016 10:10 PM
tazmans
1983 - 2012 Ranger & B-Series
02-28-2016 07:41 PM
Quick Reply: V10 Coil Pack Failure
