tires
With stock suspension and gearing, (im assuming 3.55's) Some 31" x 10.50" would be ideal, if you are currently running 235's that came stock on some Bronco's. If you are looking for a bit bigger, 32's would fit the bill without any trimming. If you want a set of 33" x 12.50's on 10 inch rims you can do it without rubbing or trimming with the proper amount of backspacing. You may want to consult the rim company for the correct one for your needs. Another option would be to purchase a set of 33" x 11.50" on a set of 8" rims. Again still, you could keep your stock 7.5" rims and stick with your metric tire sizes. 245's/255's etc.
You have lots of options.
-Matt
-Matt
fordlover
09-22-2003 07:29 PM
