Fumoto drain plugs
Originally Posted by psdjeff
I'm new to this site and have a couple of questions. I have a 2002 f250 7.3psd. Was looking into the Fumoto drain plugs. Any comments pro or con?
Good luck, Mark
Originally Posted by BigRed350
Do a search for "Fumoto". You'll find several threads with this topic or discussion. About half the people on here like them, and the other half don't. I'm in the half that doesn't!
Good luck, Mark
Good luck, Mark
I've been thinking about getting them myself, why shouldn't I?
Thanks,
Dennis
I'm in the group that loves them. I've had mine for nearly three years, and haven't experienced any of the things people worry about.
No one has crawled under my truck and let my oil drain out while the truck is parked.
I haven't snagged the valve on something in the road.
I haven't had a problem with the drain time. By the time I get another filter filled with oil, lube the front end, and get ready to start adding oil, the draining is done.
And, I can do an entire oil change using one or two paper towels. Painless.
Quote:
How do you do that? I can stay clean until I have to take the darn half-gallon oil filter off, then oil goes everywhere no matter what I do. Please explain!
I punch a hole in the bottom of my filter with an ice pick and let it drain. No mess at all.
I did an oil change when I got home from work today, and timed the Fumoto, to see how quickly it drains. I pulled into the driveway, slid a large sheet of cardboard under the truck, and positioned my bucket under the Fumoto. I flipped the switch on the valve, and started a stop watch. I grabbed a new filter off the shelf, and started filling it with fresh oil. I crawled back under the truck with a hammer and screwdriver, and punched a hole in the filter. I crawled back out from under the truck, added a little more oil to the filter, and opened a can of soda. As I was doing that, I heard the oil running into the bucket sputter. I looked under the truck, and saw that the flow of oil through the Fumoto was sputtering. It took four minutes. I ain't so busy I can't wait four minutes for 14qts of oil to drain. The Fumoto was down to a drip before the filter was.
