Replacement Frame Crossmembers?
Old 01-29-2005, 07:36 AM
Woodman79's Avatar
Woodman79
Woodman79 is offline
My 79 F250 was used for a field spray truck by the last owner. The bed is rusted out beyond belief. Bad news is the last frame crossmember is shot also. Anyone heard of picking up the crossmember only instead of a full frame replacement?
Old 01-29-2005, 08:30 AM
mark a.'s Avatar
mark a.
mark a. is offline
If you can find a good used one. You could even make one if you can't find one.
Old 01-29-2005, 10:07 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
SwOkcOffRoader is offline
i came across the same issue with my 78 F-250 sno-fighter, both of my rear crossmembers are rotted and falling off, im in the process of stripping the truck and sandblasting the frame, my idea for fixing these cross members is cutting 2 pieces of 4" square tubing a 1/2" shorter than the distance between the frame rails, welding 4"x8"x1/4" plate to both ends with 2" off either side to drill bolt holes in, and bolt these in place of the original crossmember, only thing is the plate on one end will have to be welded while the setup is bolted in........i hope i didnt loose ya......i think that when i get my frame clean, im going to box it in so its not like C channel anymore, that would be much stronger and give me a little more weight that i need......
Old 01-29-2005, 11:53 AM
Woodman79's Avatar
Woodman79
Great Idea -- thanks!! Anyone out there ever build a wood flatbed? If so, what would you change?
fordka
WTB - Parts & other
05-08-2014 04:41 PM
Broncodawg
04-10-2014 01:39 PM
cszeman
05-26-2011 02:24 AM
northeaster79
1978 - 1996 Big Bronco
12-09-2009 06:27 AM
79 F250 4XoVeRu
01-01-2003 03:55 PM
Quick Reply: Replacement Frame Crossmembers?
