Torque specs needed for 351 Cleveland
Old 01-27-2005, 10:33 AM
fordtruckman838's Avatar
fordtruckman838
fordtruckman838 is offline
Does anyone have the torque specifications for a 74 351 cleveland. I need just about all of the specs including the intake manifold progression
Old 01-27-2005, 08:20 PM
FordTruckTechNut's Avatar
FordTruckTechNut
FordTruckTechNut is offline
<TABLE cellSpacing=0 cellPadding=4 width="100%" border=0><TBODY><TR><TD width="51%" bgColor=#163d67>
Fastener Type
</TD><TD align=right width="39%" bgColor=#163d67>
Torque Spec.
</TD></TR><TR><TD width="51%" bgColor=#163d67>Main cap bots</TD><TD align=right width="39%" bgColor=#163d67>95-105 ft.-lbs.</TD></TR><TR><TD vAlign=top width="51%" bgColor=#163d67>Connecting rod bolts</TD><TD align=right width="39%" bgColor=#163d67>40-45 ft.-lbs
45-50 ft.-lbs
for Boss 351C
</TD></TR><TR><TD vAlign=top width="51%" bgColor=#163d67>Cylinder head bolts (follow factory torque sequence)</TD><TD align=right width="39%" bgColor=#163d67>105 ft.-lbs.
125 ft.-lbs for
Boss 351C
</TD></TR><TR><TD width="51%" bgColor=#163d67>Rocker arms (non-adjustable)</TD><TD align=right width="39%" bgColor=#163d67>18-22 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>5/16" Intake manifold bolts</TD><TD align=right width="39%" bgColor=#163d67>21-25 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>3/8" Intake manifold bolts</TD><TD align=right width="39%" bgColor=#163d67>28-33 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Oil pump bolt</TD><TD align=right width="39%" bgColor=#163d67>25 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Cam bolts</TD><TD align=right width="39%" bgColor=#163d67>40-45 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Cam thrust plate bolts</TD><TD align=right width="39%" bgColor=#163d67>9-12 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Harmonic damper bolt</TD><TD align=right width="39%" bgColor=#163d67>70-90 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Flywheel/ flexplate bolts</TD><TD align=right width="39%" bgColor=#163d67>75-85 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Pressure plate bolts</TD><TD align=right width="39%" bgColor=#163d67>35 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Front cover bolts</TD><TD align=right width="39%" bgColor=#163d67>12-18 ft.-lbs.</TD></TR></TBODY></TABLE>that should doit. as for progression start with half of the desired torq start in middle and work your way out in a criss cross circle.
gatnos
06-05-2020 11:44 AM
351Cleveland C4
25
03-08-2016 06:00 AM
Pedestrian
08-24-2008 08:19 PM
calazo
16
06-23-2004 04:46 PM
scottjohn
09-22-2002 01:06 AM
Quick Reply: Torque specs needed for 351 Cleveland
