Head gasket job final stages
Old 01-25-2005, 10:27 AM
vekrause's Avatar
vekrause
vekrause is offline
So I've replaced the head gasket, head bolts, radiator, water pump, timing belt, spark plugs and a whole lota' tubing. When its all put back together, what should I do about the remaining contaminated coolant still in the block? I was thinking about filling it with a little antifreeze and water and running it up to jiffy lube and gettin' it flushed. (I know, I know, but we're lucky if it gets to 32 degrees out, and disposal is their problem).
Any suggestions?
BTW, I searched quite a few posts about removing the damper, bracing the wrench on the ground and kicking the starter didn't work. Two ratchets and a new breaker bar later, I finally got the bolt using a 24" pipe wrench to hold the damper, and my new breaker bar with a lot of muscle.
Old 01-25-2005, 07:05 PM
Chris_ce's Avatar
Chris_ce
Chris_ce is offline
You could do that or buy the little flush kit that hooks into the heater hoses.
MauleOne
09-13-2014 12:03 PM
TheHades
02-21-2014 03:46 AM
padd54
10-04-2012 06:16 PM
DISLFVR
01-10-2012 05:12 AM
aerocolorado
Aerostar
07-19-2007 04:23 PM
Quick Reply: Head gasket job final stages
