Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-26-2005, 11:02 AM
psmith338 psmith338 is offline
psmith338 is starting off with a positive reputation.
Mercon SP Tranny Fluid
It's time to service my tranny. I found a great deal on filters at Filter1, but I can't find the fluid anywhere but the Ford dealer & they want $4.62 a quart!
Any suggestions?
  #2 (permalink)
Old 01-26-2005, 12:55 PM
rstokes rstokes is offline
rstokes is starting off with a positive reputation.
It's called GOTCHA! Swallow hard and go ahead and pay the FMC dealer's price because that's the only place to my knowledge (and I've checked it out fairly well) that you can buy the SP and any other fluid will ruin your transmission or at the least void your warranty, if discovered. Sorry, there's no shortcut on this one.
  #3 (permalink)
Old 01-26-2005, 05:19 PM
tn mac tn mac is offline
tn mac is new and has a neutral reputation at this point.
also there is no way to drain the fluid out of youe torque converter except the flush and drain system the dealer or trans shop has,without getting all the fluid out it kinda a waste.
  #4 (permalink)
Old 01-26-2005, 06:56 PM
fyrhog's Avatar
fyrhog fyrhog is offline
fyrhog is starting off with a positive reputation.
Mercon
I wonder where the trany shops get Mercon?
__________________
F-350 SD Dulley SC 4x4 Auto V-10 Larriet
  #5 (permalink)
Old 01-26-2005, 11:12 PM
keith58 keith58 is offline
keith58 is starting off with a positive reputation.
fmc.
aftermarket shops buy from the direct maufactureres all the time
  #6 (permalink)
Old 01-26-2005, 11:26 PM
bdjupiter's Avatar
bdjupiter bdjupiter is offline
bdjupiter is starting off with a positive reputation.
Look up at the tech articles at the top of the page, then go to transmission and read up. I did what was indicated and changed mine this summer. It was easy and let the wife feel like she was helping by starting the truck and turning it off. I used Mobil synthetic and the truck runs and shifts like a champ and I won't have to do it again for quite a while!
__________________
2000 5.4L F-250 SC 4X4
Diablo Chip
Gibson Exhaust
K&N Stage II
Wheels & Tires
  #7 (permalink)
Old 01-27-2005, 08:25 AM
SBV45's Avatar
SBV45 SBV45 is offline
SBV45 is starting off with a positive reputation.
In Central Texas I found Mercon SP at a local parts house that is owned by Arnold Oil company, a local distributor.
The 30k maintenance only calls for a drain and fill and external tranny filter change. The flush is extra and not necessary. I did the drain and fill. It took 8.25 quarts. I know a local trans shop that won't do the flush.
__________________
03 F250SD 4X4 6.0L PSD 5speed auto. 3.73 diff, extended cab, Raven shell. 4/2/03 build, 3/27/03 engine build.
  #8 (permalink)
Old 01-27-2005, 02:27 PM
turbohatch turbohatch is offline
turbohatch is starting off with a positive reputation.
I know Valvoline has Mercon V SP in synthetic blend.I don't know the price but I hope this helps.
  #9 (permalink)
Old 01-27-2005, 03:02 PM
Casey Casey is offline
Casey is gaining momentum as a positive member of FTE.
MERCON V is different from MERCON SP. You can't use MERCON V in a TorqShift without causing problems.
  #10 (permalink)
Old 01-27-2005, 03:18 PM
SBV45's Avatar
Quote:
Casey is right on. Read your owner manuals.
Quote:
Some transmission fluids may be labeled as dual usage, such as
MERCON and MERCON V. These dual usage fluids are not to be used
in an automatic transmission that requires use of the MERCON type
fluid. However, these dual usage fluids may be used in transmissions that
require the MERCON V type fluid.
MERCON, MERCON V and MERCON SP are not
interchangeable. DO NOT mix MERCON, MERCON V and
MERCON SP. Use of dual usage fluids in an automatic
transmission application requiring MERCON SP may cause
transmission damage. Use of a transmission fluid other than the
recommended fluid may cause transmission damage.
__________________
  #11 (permalink)
Old 01-27-2005, 08:34 PM
SBV45
If you dont do the flush how do you get the fluid out of the converter,there is no plug,seems kinda like changing your oil and not the filter to me.
  #12 (permalink)
Old 01-28-2005, 08:39 AM
There are two ways to get the oil out of the torque converter. One is the flush method, and the other is to take the torque converter out of the transmission and drain it.
I use the flush method. Pulling the trans each time I need to change the oil is too much work!
  #13 (permalink)
Old 01-28-2005, 11:15 AM
SBV45's Avatar
tn mac,
You are right, the new fluid mixes with the old. Drain and fill is a recommended procedure. Both drain and fill and flush are shown in the service manual. There is no recommendation or cautions on mixing the trans fluid or concerns on not draining the torque converter.
I looked at the fluid on the dipstick prior to changing. It was still red and clear. I spoke to the manager of a transmission shop that I know and trust. His shop doesn't do flushes. He said on a new trans, he would be okay with doing a flush, but it isn't necessary. Just don't go any longer than the recommended maintenance period.
As for comparing the trans drain and fill with changing oil without changing the filter, you don't have the internal combustion process going on in your tranny. I got your idea, just not the same.
__________________
  #14 (permalink)
Old 01-28-2005, 04:12 PM
I agree not quite the same but it gets the fluid pretty hot, and it also gets dirty, guess this is one of those times we agree to disagree. would that be a another time warp thing, ha ha.
  #15 (permalink)
Old 01-28-2005, 06:21 PM
kb1aah's Avatar
kb1aah kb1aah is offline
kb1aah is starting off with a positive reputation.
Question Transfer Case?
So what about changing fluid on the transfer case? I don't beleive it shares the fluid with the trans like some vehicles. What is the schedule for this? What type of fluid does it use?
__________________
2004 F250 6.0 AUTO CC SB SRW LARIAT/FX4
2006 F450 6.0 AUTO CC Chariot Custom (work)
2007 F350 6.0 AUTO CC LB SRW XLT/FX4 (work)
2007 F650 5.9/Allison (work)
Tags
automatic , buy , engine , fluid , flushing , ford , information , mercon , merconsp , mixing , msds , oil , sp , transmission , vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
