Overdrive Off Switch Not Working
I Have A 2000 F250 Sd, Just Bought It. My First Ford. Anyway, The Overdrive Off Button On The Shifter Is Not Working. The Light Doesn't Come On And The Tranny Doesnt Kick Out Of Overdrive. I Have Replaced Switch Assy With A Known Good One, As Well As Checked The Fuse ( 10 Amp, # 19 On Panel). Any Suggestions?
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
No need to pull the air bag or wheel.
Disconect the battery cables. Remove the screws (3) from bottom on the plastic column cover and remove the lower section. Insert your ign key and turn the key to the "on" position. Looking from the bottom up at the ign cylinder the is a small hole/bore,(~3/16 dia) insert a small pin puch in the hole, this will release the cylinder asm, pull the asm straight out. Remove the upper colume cover. Follow the wires for the OD switch to locate your "broken wire".
The cut or brake can be very small. I had one with a brake in the insulation just big enough for two strands of wire to ground out.
Good luck.
Good luck.
Dillon Rogerson
02-08-2016 03:51 PM
cacarroll
1983 - 2012 Ranger & B-Series
08-14-2006 08:13 PM
