Calgary FE Guys
Well i'm headed through Calgary on thursday and i'll be looking for some coffee probably around 2 (not entirely sure on that though) before my physio appointment (hopefully Waxy will be able to join too), if you're up for it name a good place down on Mcleod trail when you first come into calgary.
Hopefully we can get something decided on the stickers on thurday (see Coffee at Timmay'sss, Red Deer for whose going to be there) .
Sorry i missd but but here's what happened, remind you, that we haven't really dove this truck, an 88 ranger, to work all the bugs out, but here it is:
So here's what happened, as i was pulling into calgary on Mcleod i noticed that the temperature gauge was rising and i thought it was because of the weather cover thingy i had over the grill, but as i turned off into the road that took me to the South Calgary Health center the heater quit working (blew cold air), and the temperature guage started climbing real fast, so i hurried to the parking lot and shut if off before i cooked the motor.
When i got out i noticed that antifreeze was leaking pretty steadily from some where on the back of the motor, and then i knew exactly what it was (dad point it out yesterday when we changed the t-stat that a hose somewherre back there was leaking) there is a steel line that comes off the heater hose that goes to the intake manifold so as to keep the intake warm, and this steel line is just loose back there so it vibrates, and off choose it is lying right on the valve cover and it wore a hole about the size of a pencil tip in it and it leaked out all the antifeeze, I'm just luckly that it was minus 30 degrees the whole trip up so the motor didn't over heat.
So now i had to go find a place to fix this, and i ended up in front of a parts value store leaning under the hood in the cold @$$ weather trying to remove this line, once i got the line out (the dang hose clamps are right down in the most imposible spot to get at, and i what took me so dang long), i bought a lenght of 3/8 heater hose and slid it over the hole in the line and then hose clamp it at each end and over the hole so as not to wear another hole in the line. By the time i finshed up with everything and got the antifreeze levels right it was a quarter to 4, i knew you would've been gone be then, and so i left so i would be able to make it for red deer on time.
Talk about a bad day, anyway next time i come through Calgary i will be sure to stop in at the "south Tower" for lunch or something, my treat, and anyone else is more than welcome to join, and Waxy, maybe this time i can catch you on a day off or something. (if either of you just want to talk)
But again, sorry i missed you i was really looking forward to a plate of wings.
yeah and this morning my dad called and said that the other truck i would've taken (93 supercab 4wd, 31's, 302 and that POS mazda 5speed) broke down on my mom at 5 in the morning, something broke in the tranny so it won't engage in gear, time to swap out in favor of the good ol' 4sp and gear t-case.
