The Dana70 is bigger. Look at the housing on one of the sides, it should say either 60 or 70 stamped right on it. If your truck is a one ton then most likely it is a Dana70.
The one close and more rusty is a Dana70, the far one is a 60. Notice the bigger pumpkin and axle tubes on the 70.
