Bearing Oil Clearence, is .0035 In. Too Much?
While putting my motor back together, I plastiguaged the main and rod bearings and came up with .002 to .0035 thousands. The book lists a maximum of .0026. Is this extra thousand going to be enough to cause low oil pressure or knocking? or do you guys think it will be ok? I have a high volume oil pump also. The motor is a 93 300.
Thanks,
Andy
Thanks,
Andy
I got the hi vol pump from Napa auto parts. They were the only one in my area that could get it.
74F250: When oyu say "out by 2 thousands" do you mean 2 thousands clearance or 2 thousands over the maximum recomended?
I think I will check one with the old bearings to see what it was before. All of the bearings had copper showing and it had little to no psi at idle when warm and would knock when I let off of the gas to shift gears or when the motor was at higher RPM with not much load. I wish I wouldn't have already bought all of the bearings, Live and learn I guess.
Thanks,
Andy
Thanks,
Andy
Look at the back of the old inserts and if they are undersized it should be marked.
Today it is pretty common practice for manufactures to use a standard insert combined with a one under insert on the same journal to arrive at desired clearances. I would guess that a good supplier would exchange the inserts should you need to do so and if they were not installed.
Hazelwoodgarage
01-08-2016 04:54 PM
Goose_52
06-23-2012 01:51 PM
Michigan Rick
19
05-15-2009 06:20 PM
andy_547
12-31-2004 04:31 PM
