49 ford f1 transmission
I am helping a guy with a 49 ford f1 panel van. The owner wants to go through the engine and transmission. I am going to try to pull out the motor and tranny together. My question is how to remove the shifter from the transmission. I see there is a cover with 6 bolts below the shifter. Do I take those out and shifter comes out with the cover? Thanks, Andy
on
1 Post
stick shift
When you take the cover off, make sure the lever is in neutrel, it will make puting it back in a lot easier. When the cover comes off, you'll see what I mean. Also, on some of the towers, you have to push down on the cap as you are unthreading it. Been there, done that!
Good luck,
Jim
Good luck,
Jim
I thought this video may help someone too
Ford shifter removal - YouTube
Irish916
07-20-2016 08:20 PM
Mercury Bluz
07-29-2008 08:21 PM
bobs50fordpu
11-30-2002 06:29 PM
