4 speed transmissions
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE
We are happy to have you on board!~
Enjoy FTE
if it has PTO covers on both sides its a T-19.
np435 has the lowest unsycronized 1st gear.
T18 has a higher unsycronized 1st gear
T-19 comes is a couple configurations , a close ratio and a wide ratio. the wide ratio has a sycronized granny 1st gear. the close ratio has a sycronized 1st gear.
the T-18, T19 are concidered stronger because they were both used as OEM in medium duty trucks. the NP435 was only ever offered in light duty trucks.
While the others are concidered stronger, the NP435 is one tough transmission.
glangwell
08-30-2003 02:38 PM
