460 crank 429 pistons ?
is it possible to use 460 crank and rods with 429 scj 11.3 pistons? . if not is it possible to get different rods ? i broke my 429 crank and i have a new 460 crank that i am thinking of using , the pistons asre forged alum so i would like to reuse them. dove heads and 560 lift cam if u need to now.,
well in searching prev threads i think i got my answer 460 crank will not work with 429 pistons, are their any other options other than buying new 429 crank? i realy want to keep these pistons they cost me an arm and aleg, speed pro forged alum 40 over pistons 1200 canadian , did they see me coming or what!. motor is for mud racer under 2800 lbs, need to get most power i can since crank is broke i want to make sure i buy a good one this time
the only thing different between the 429 and 460 is the stroke. It would have been my assumption that the crank was not the same for the different stroke and that the connecting rods were longer to reach the top of the cylinder, but from this post the connecting rods are the same, but the pistons are longer to make up the height differance, correct?
yes u r correct. the compression height or distance from the top of the piston to the center of the rist pin r different between the 429 and 460. the rods r the same lengh. and the crank is a different stroke. if i remember correctly the compression distance on the 429 is greater then the 460 so if u used 429 pistons on a 460 crank they would be shoved into the head preventing the crank from moving and on the same token if u used 460 pistons on the 429 crank the pistons would never reach TDC. so in other words when ur rebuilding 1 of these motors make sure u know which is which.they made both the 429 and 460 for several years but.
Dialtone
10-24-2009 07:31 PM
gabraham
06-16-2003 06:41 PM
gray79f250
01-16-2003 10:58 PM
