P0401 and P0402 codes?
Ok, I took apart my throttle body, cleaned out the carbon buildup on it, and the spacer.
It ran great and no problems for about 100 miles, then, instead of giving me the P0402 error, it's giving me both the P0401 AND the P0402 error.
It was told to me that the issue is probably the EGR position sensor? Does this sound right to everyone?
I had the similar codes throwing on my truck. Here's the thread from here that helped me out. It was my DPFE sensor that was the cuplrit. $36 and the truck was fixed. Hopefully this helps you out.
https://www.ford-trucks.com/forums/s...d.php?t=224616
Jason
Jason
I replaced the DPFE sensor and waited a few weeks before posting the results. So far, I've seen:
No more check engine lights
Better gas milage
Better acceleration
No more knocking when accelerating from a low speed
Better overall performance
Would the sensor really be a factor for all those things?
Better gas milage
Better acceleration
kc5deb yes it's possible that replacing the DPFE will fix all that.
When the check engine light is on the engine runs in "open loop" which means that different sensors aren't controlling the air/furl ratio, ignition timing etc. It goes into a failure mode and sets everything at predetermined values which is usually more gas, less timing advance.
youngphotons the EVP sensor can be replaced seperately from the EGR valve and shouldn't cost very much. Getting it scanned and tested at your dealer would be best to verify that's the problem. We used to replace lots of those. If the engine idles smoothly the problem is probably the EVP.
