Dead ABS System?
Old 11-14-2004, 10:03 PM
Cruiseomatic's Avatar
Cruiseomatic
Cruiseomatic is offline
Dead ABS System?
Hell,my ABS is really off. Back only locks,front doesnt. Then if you apply a little too much pressure,wheel lock. ABS light doesnt comeon. Front doesnt lock either. Just keeps rollin. It's scarry knowing if I gotta stop hard,only my rear wheels will stop me and this is my only car and daily driver.
My E-Brake warning light comes on when I try to crank it,but on the "On" position,Its off. And ABS light lights up on Ignition "On" Position,then shut off as I go to crank.
Thanks.
Old 11-14-2004, 10:16 PM
midlf's Avatar
midlf
midlf is offline
What year
What year, model is your truck? It makes a difference. Is it a RABS (rear wheel ABS) or a 4WABS (all four wheel ABS)?
MIDLF
Old 11-14-2004, 10:25 PM
mike L's Avatar
mike L
mike L is offline
getting Abs Codes
The haynes manual says if the abs light is on and while the truck is running to check the trouble codes on the Rabs connector, behind the glove box.
Old 11-15-2004, 09:09 PM
Cruiseomatic
Its an '89 with RABS.
Old 09-02-2014, 01:05 PM
mike L's Avatar
mike L
mike L is offline
Do you remember if is was a bad rear end wheel sensor? Did only one wheel lock up? Did you pull the ABS fuse out until you found out what the problem was? I'm working on my ABS system, I got fuse out for now.
TallTexan
1997-2006 Expedition & Navigator
04-20-2015 07:44 PM
polish dude
1999 to 2016 Super Duty
01-15-2015 09:18 PM
edsheridan
08-25-2014 02:39 PM
Enduroman
12-06-2013 02:53 PM
tfreitas
10-22-2013 07:27 PM
Quick Reply: Dead ABS System?
