Hey folks where is the best plce to get an over head console for the superduty. I have 1999 and ike the idea of the overhead console....also are all the SD'S prewired for the console??
I put in an overhead console in my 2002 SD F250. All the parts guys and salesmen swore it wouldn't work. I cut the hole with gritted teeth and found everything ready to accept it. I then fed the wire down the passenger side post next to the windshield down to a side panel next to the floor. I found a dummy plug in a receptical the same size as what I needed to plug into. To my joy it plugged in and worked. The only flaw I found was the miles to empty is half what it should be but it's a small nusance.
You'll have to include a wiring harness if you want to hook one up.
