Zoodad Mod
Okay try this, open the hood. Look at the air filter housing, there is a section that will go into the grill area (kinda sorta). Now look at the small section of the grill, the two areas interconnect. If you were to use a hole saw (IE to install a door ****) you can drill out that fiberglass area to increase airflow into that area. The orginator of this used the forum handle of " ZOODAD", hence the mods name.
I don't think links work in here but I am going to try to put a couple in anyway.
http://client.webshots.com/album/201377753pOjrTB
http://www.eagleoutpost.com/How-To/Zoodad/zoodad.html
If they wont work copy and paste these into your browser.
I read on here some place that this mod lets water in and can be a problem in a downpour but I have never tried it myself.
