Super Charger
BDS has 'em. ( http://www.blowerdriveservice.com/blower_comp_kit.html ) A 360 is an FE block and BDS has them for 390-428's...which are FE blocks. You can contact their tech and they'll tell you what you need to do to make it work.
Norb
Norb
The kit will set you back around $3700.
I run a Blue Thunder blower manifold with a stock 6-71 blower on my 390. 6 lbs of boost really peps it up
I would watch, as I have mentioned before to others that have thought about this project......the blower/carbs are back pretty far and MIGHT interfere with the rear of hood/cowl area. Now, this is with my Blue thunder intake, maybe others will move it forward. A good way to guesstimate would be take a ruler and line it up with rear of manifold. As it points up, what does it hit?? Anything directly above will be in the way of blower/carbs. I had thoughts of installing this motor in my '69 F100(before putting it in my '64 Galaxie) and after determining the clearance issues I passed on the idea.
Just want to pass this on. Don't want you to find out AFTER you get it done that it doesn't fit right.
